What is this?
Hyspeedz
  • Replies 3
Yes it bolts to the exhaust manifold bolt. Take a look and you will likely find the other end there. I wouldn't try unbolting it for fear of snapping the stud off, instead crimp a lug on the end of the wire and install it under a valve cover bolt nearby.  Grounds are always good to have and this may make it run better.
