bmacster Posted August 26, 2013 Report Share Posted August 26, 2013 What's up everyone! Been a while since I have been on here with the new job. Been very busy and making that money finally. With the suspension mostly done, I still need to repair the hole that the PO cut into the frame to repair the broken camber nut welds but before that can happen, I need to get the steering box replaced. I tried to adjust it and it was still fairly loose, which I can only assume at this point, that the box is wore, now with the tight suspension. Any suggestions on where I can find one? I have tried rockauto, napa, autozone, etc, etc, and no one has one available. Truck is a 85 720 4x4. Thanks guys! Quote Link to comment
wayno Posted August 26, 2013 Report Share Posted August 26, 2013 Try a wrecking yard, just find a tight one. :) Quote Link to comment
