Joeoski Posted August 4, 2013 Report Posted August 4, 2013 What one of these are the one to go with the green white or yellow ? http://www.ebay.com/itm/231025824952?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 http://www.ebay.com/itm/231025825985?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 http://www.ebay.com/itm/330975026177?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 I already stabbed my cylinder number 2 two times with the junk scrapper i got from harbor freight so going to go for this type of thing now. Quote
Joeoski Posted August 4, 2013 Author Report Posted August 4, 2013 Here is the scrapper i got this does not get under the gasket for nothing wish i never bought it . http://www.harborfreight.com/carbon-gasket-scraper-98507.html Been thinking of trying the razor with lacquer thinner and the rags. Quote
datzenmike Posted August 4, 2013 Report Posted August 4, 2013 Get something like this... I just use a 20 year old paint scraper. On the block a small brass wire wheel in an electric drill. Won't hurt the cast block. If you do use on the head have a care the aluminum is very soft. You shouldn't need thinners if the gasket was installed properly. It should have been put on dry. Quote
Joeoski Posted August 4, 2013 Author Report Posted August 4, 2013 It seems like it was super glued to the block in the rear area and the exhaust side , I will try that paint scraper then other options. Quote
byrnzy Posted March 2, 2020 Report Posted March 2, 2020 fellas what is the correct way of unbolting the head on an L16????? need to get my buggy running Quote
datzenmike Posted March 2, 2020 Report Posted March 2, 2020 First and foremost, block the chain tensioner from falling out before you unbolt the cam sprocket. Keeps this part .... from doing this... Once out of place you have to take the front off the engine to correct. I would disconnect the exhaust down pipe and lift the head away with the two manifold on it. Get help lifting it off. There's no need to remove them or... it's much easier with the head off the engine. Loosening the head bolts? I just break them all loose 1/2 turn then unscrew and remove them. Putting them back on requires that they be done in a certain order and properly torqued in stages. Quote
byrnzy Posted March 3, 2020 Report Posted March 3, 2020 sweet thanks man, itll proabably be better to ask you about this when ive actually got the engine in front of me so i can tinker with it as you tell me how to haha. ill be able to work on it this weekend so if you dont mind ill message you this weekend on how to do it and well go from there. cheers mate Quote
