Datkid Posted August 8, 2008 Report Share Posted August 8, 2008 Engine: Around 140k less that 600 miles- Head gasket valve cover gasket valve stem seals water pump oil pan gasket timing chain clutch O2 sensor rebuilt injectors w/1000 miles Tranny goes into gear w/ no grinds come with aftermarket sohc header custom short intake with k&n filter emissions delete engine harness lower harness 5speed ecu sohc cluster price- $500 Call or text ( fastest response) 425-346-7647 Kenneth Located in Everett,wa Link to comment
b210in Posted August 8, 2008 Report Share Posted August 8, 2008 Engine: Around 140k less that 600 miles- Head gasket valve cover gasket valve stem seals water pump oil pan gasket timing chain clutch O2 sensor rebuilt injectors w/1000 miles Tranny goes into gear w/ no grinds come with aftermarket sohc header custom short intake with k&n filter emissions delete engine harness lower harness 5speed ecu sohc cluster price- $500 Call or text ( fastest response) 425-346-7647 Kenneth Located in Everett,wa dam, dude i wish you were closer. the shipping alone would eat the killer price. Link to comment
AZhitman Posted August 30, 2008 Report Share Posted August 30, 2008 Argh, same here. Keep me in mind if you absolutely must offload it. Link to comment
ppeters914 Posted September 7, 2008 Report Share Posted September 7, 2008 Damn. I'm only minutes away, but SWMBO would kill me. Link to comment
