Better brakes without 280zx strut
Eriks
  • Replies 3
For struts, all bolt in if you swap around the top hats and springs in most cases.
The one added benefit of the 280ZX brakes is the decreased width which allows you to run an additional -19 offset that you couldnt before. ZX struts are the only ones that do that... rest are close to stock or even more positive offset.
