SASdatsun Posted July 12, 2013 Report Share Posted July 12, 2013 Has any body tried the performance cams for the z24's? Or the header? What kind of power gains are y'all seeing? Quote Link to comment
datzenmike Posted July 12, 2013 Report Share Posted July 12, 2013 Because of head and valve design you can't run big lift or duration or they will touch. Headers only add a few hp at extreme RPM where the Z series don't go. They are expensive and high maintanance like a trophy wife and hard to put up with in the long run. If you don't believe me at least keep your old exhaust manifold.... you'll need it when you change your mind. If you want the biggest bang for your dollar get a new weber carb. Quote Link to comment
SASdatsun Posted July 12, 2013 Author Report Share Posted July 12, 2013 Ok thanks. Cam and header is alot of $$ for not much power. 38/38 weber on the way already! Quote Link to comment
