A/C on a ka swap
Fckieffer
  • Replies 4
I'd think you'd need to make sure you have room between the block and your gear box.  Not a whole lot of room between there.  The Ac compressor would sit right next to it.  Maybe find a very small compressor??  Then from there all you would need to do is run your hoses to the accumulator and condenser.  Do you have all the components to run the AC?
