91hrdbdy Posted June 26, 2013 Report Share Posted June 26, 2013 Forgive me if this info is all ready out there. I have a brand new set of 20" wheels with tires that i had on my hardbody for about 300 miles i was wondering if these are gonna fit. im asking because there up a my old mans house about 7 hrs away and if they will fit on my truck with a 3/4 drop ill go up and pick them up. there 20x8.5 with a -35 offset im running a 225/35/20 tire. any help would be great. i need to either buy new tires for the 15" that are on it or go get these. Quote Link to comment
Eagle_Adam Posted June 26, 2013 Report Share Posted June 26, 2013 i have 18 in nissan titans on my 620, urs is a 74 so you have drums on all 4 corners. Meaning you should be able to run them.... im just not sure about the offset Quote Link to comment
Dawa Posted June 26, 2013 Report Share Posted June 26, 2013 assuming your stock wheel/tire size is 195/75/14, 225/35s on a 20 are only .7" larger in diameter, or .35" larger in diameter. so you should be good, even on a lil drop i think you can plug in sizes here http://rimsntires.com/specs.jsp Quote Link to comment
91hrdbdy Posted June 26, 2013 Author Report Share Posted June 26, 2013 my truck has been converted to disc brakes allready the wheels will clear the hub there were made for my Hardbody with a 4.125 hub opening. Dawa i was mostly concerned with the width. on a side note what boats were you on. i was a sts on kentucky alaska and did 2 years on a p3 in whidbey before i bailed out. Quote Link to comment
Dawa Posted June 26, 2013 Report Share Posted June 26, 2013 oh damn -35 on an 8.5, daaaaamn. i was on the nevada (blue) 05-09. shore duty in sd now Quote Link to comment
91hrdbdy Posted June 26, 2013 Author Report Share Posted June 26, 2013 I WAS IN BANGOR FROM 06-09 Quote Link to comment
