84720FourWheel Posted June 12, 2013 Report Share Posted June 12, 2013 I apologize in advance for the lack of pics. So I bought a truck today, ($950!) and when i shut it off, it shuts down a little rough and sometime diesels a little. I figure its that little solenoid on the carb. (Been doing a little research) And it idles at around 1600 RPM and the factory sticker under the hood says 800 RPM So that should be able to be fixed my a throttle cable adjustment or idle speed screw. Correct? My main problem here, is that I need to take off the air cleaner assy. Any tips or tricks for this before I jump in? Also Z24 Engine Quote Link to comment
84720FourWheel Posted June 12, 2013 Author Report Share Posted June 12, 2013 Pics Delivered! Bed is in good condition Quote Link to comment
bryant2482 Posted June 12, 2013 Report Share Posted June 12, 2013 needs a weber! that will solve the issue. the stock carb limits this engine so much Quote Link to comment
84720FourWheel Posted June 12, 2013 Author Report Share Posted June 12, 2013 needs a weber! that will solve the issue. the stock carb limits this engine so much Haha, I think my brother might have one laying around. Not sure if it will fit though. Also, I'd like to get this one adjusted right, and save the weber for a rainy day. Quote Link to comment
bryant2482 Posted June 12, 2013 Report Share Posted June 12, 2013 yea just run it til it really takes a shit lol. i did that with my old Hitachi. i did have to change out the fuel solenoid but even after that the rpms were all over the place and it idled rough. you could also have a broken emission line or one that popped off. i would spray carb cleaner around the hoses and listen if it bogs down Quote Link to comment
