z18et in 1985 720?
Bambam91
as above. can it be done? has anyone done it before?
i have a 1985 nissan datsun 720 4x4 and my z24 sounds like the big end bearing is on the way out.
theres a z18et listed on gumtree.com.au for $300 - http://www.gumtree.com.au/s-ad/woodville-west/engine-engine-parts-transmission/nissan-z18et-complete-motor/1020702069
includes:
- engine and all accesories
- ecu & loom
- inlet manifold
- exhaust manifiold
- throttle body
im from australia by the way hence the aussie website :P
cheers, Mat
  • Replies 4
I wouldn't do this. It would be like using a race horse to pull a cart.  Z18 (Arabian) is too small to pull a pig heavy 720 and will be in boost mode all the time. The Z24 (Percheron) is a torque monster totally suited for pulling it.
Yes it can totally be done they are both Z series motors. You'll need the Z24 oil pan to clear the front differential. If the Z18 does not have a flywheel on it the 6 bolt Z24 wheel may not fit if the Z18 has a 5 bolt crank. On the other hand the turbo motor may very well have a 6 bolt crank.
