BEAST KC Posted May 26, 2013 Report Share Posted May 26, 2013 can anyone tell me if the ld20t will mount up on the stock mounts. i have heard this is true but wanted to confirm. Quote Link to comment
wayno Posted May 26, 2013 Report Share Posted May 26, 2013 can anyone tell me if the ld20t will mount up on the stock mounts. i have heard this is true but wanted to confirm. Welcome to Ratsun B) There are very few that can actually answer this question, as that engine did not come to this country in a 620, or a 720 for that matter. Which engine do you have/want to buy, there are two completely different engines that are LD20T, one sorta looks like an L block, the other is a more modern looking engine using belts instead of chains and gears? Quote Link to comment
BEAST KC Posted May 27, 2013 Author Report Share Posted May 27, 2013 haven't bought one yet, doning little research first. the one that looks like the L, i read in wiki that it came in the bluebird and vanette and that it would bolt right to 620 mount. that it would been better choice than sd22 because of that? Quote Link to comment
