travis06lly Posted May 22, 2013 Report Share Posted May 22, 2013 I have some 18" titan wheels I want to get the center bore bored out so I don't have to use spacers! Can someone tell me the center bore size of the 620 please? Quote Link to comment
Eagle_Adam Posted May 22, 2013 Report Share Posted May 22, 2013 your better off machining your hubs! Quote Link to comment
Eagle_Adam Posted May 22, 2013 Report Share Posted May 22, 2013 but if you must Quote Link to comment
Eagle_Adam Posted May 22, 2013 Report Share Posted May 22, 2013 http://community.ratsun.net/topic/48684-titan-question/ Quote Link to comment
travis06lly Posted May 23, 2013 Author Report Share Posted May 23, 2013 What do you mean machining the hubs, grinding down the part that sticks out? Quote Link to comment
Eagle_Adam Posted May 23, 2013 Report Share Posted May 23, 2013 yup, you could use an angle grinder or take thr hubs off and have them turned in a break lathe Quote Link to comment
Dawa Posted May 24, 2013 Report Share Posted May 24, 2013 bro if you have a 620 why dont you just go get a ruler/measuring tape and go measure your hub? then convert the inches to MMs. 1in = 25.4mm then measure the bore of the wheels Quote Link to comment
