edekalil Posted May 22, 2013 Report Share Posted May 22, 2013 I have a 4 speed trans that worked fine till at some point a pin must have sheered that holds the part at the other end that controls the shifting forks. Is that easy to get to to fix? I think you only have to remove the tail section of the trans. Is there anything to be aware of if so? Eddie Quote Link to comment
MicroMachinery Posted May 22, 2013 Report Share Posted May 22, 2013 If it's the pin I'm thinking of, you can use a bolt and a nylock nut in place of the pin. I've had a few transmissions that came like that and worked fine. Quote Link to comment
edekalil Posted May 22, 2013 Author Report Share Posted May 22, 2013 If it is not much trouble to take off the tail end of the trans then I could for sure put in a bolt with a nylock nut. Thanks Eddie Quote Link to comment
edekalil Posted May 27, 2013 Author Report Share Posted May 27, 2013 Before I do this I am wondering, when you unbolt the tail end of a 4 speed manual trans from a 510 will the tail end just come off? Is there anything to be aware of that may fall out. I only ask because I have never taken one off. I'm just not sure if there is any surprises to be aware of before removing the tail end. As well as putting it back on. Is it as simple as unbolting and pulling apart? Or is there anything I need to know before I pull it apart and put it back together? Eddie Quote Link to comment
edekalil Posted May 28, 2013 Author Report Share Posted May 28, 2013 Well I got it working, unbolted it pulled it loose. Some how the lever attached to the other end from the shifter had slipped out of place. When I put back on it seemed to go in and out of gears ok. So I guess it will be ok Eddie Quote Link to comment
