Lowandslow Posted May 17, 2013 Report Share Posted May 17, 2013 I have an 80 l20b 720. The choke is not opening up completely. It opens up like 2/3 of the way. I have no power when I have to floor it. I moved the adjust so it would open up all the way and I actually had power!! But no idle. Is there any other adjustments I can do? Or a cold idle circuit I can adjust? Quote Link to comment
datzenmike Posted May 17, 2013 Report Share Posted May 17, 2013 The choke heater appears to be not working. Get a $5 test light. Check for power on the Blue wire going to the electric choke when the motor is running. Opening 2/3 is just the heat from the motor opening it. The round Black thing is the choke heater. The wire from it is actually Blue. Check that it's plugged into the engine harness and the test light should light with the engine running. Quote Link to comment
Lowandslow Posted May 18, 2013 Author Report Share Posted May 18, 2013 Okay so I did this and the light did not come on. I tested a couple of other things to make sure it worked and the test light works. Quote Link to comment
Lowandslow Posted May 19, 2013 Author Report Share Posted May 19, 2013 I have connected the choke heater wire to the ignition switch so now it has power when the engine is on. The truck dies now when the choke is completely open. It idles for a second then it gradually loses RPM's and dies.I have the idle screw out 2 turns. Quote Link to comment
