SlammedhappySteveO Posted May 16, 2013 Report Share Posted May 16, 2013 I realize its probably been done to death... But im mobile and cant seem to find the post... I want to maks sure the install is perfect the first time! Wishful thinking i know..... Any picture , links, diagrams or whatever would be spectacular... Tbesuns out and i need to be driving this thing! Thanks to all in advance! Quote Link to comment
izzo Posted May 16, 2013 Report Share Posted May 16, 2013 there is no proper diagram. The stock carb may have a few vacuum lines, the weber only has 1. Hook that 1, up to the distributor. you'll have to block the rest off. If you don't live in an emissions area, this'd be a good time to do emissions delete. Quote Link to comment
SlammedhappySteveO Posted May 16, 2013 Author Report Share Posted May 16, 2013 No emissions in bremerton.... Jus didnt wana block the wrong ish, know its been done on here, so wondered what worked n what didnt.. Quote Link to comment
izzo Posted May 16, 2013 Report Share Posted May 16, 2013 just make sure your vacuum advance is plugged into the carb from the dizzy. The dizzy usually has like 3 vacuum lines on it. Make sure you get the right one. The rest you can block off. Don't block off the PCV system, either hook that up to the air filter on the weber or leave it alone, but don't plug it. Good to go mang... Quote Link to comment
