ArmlessMechanic Posted April 30, 2013 Report Share Posted April 30, 2013 I'm hoping you guys can help me out here. I took my block up to Darton to get some work done. When I got the block back it didn't have the "blow-by" hose anymore. I am wondering if anyone has a spare one or knows where to get one. I called Darton and they said they had to cut it out of the block because it was siezed in there. A friend of mine said that I could tap it and put an AN fitting in there and just go about it that way. Any thoughts anyone? I can't upload pictures to the site from my work so those will have to wait. For reference, it is the tube that is pressed in on the exhaust side of the block towards the back. Link to comment
510T Posted April 30, 2013 Report Share Posted April 30, 2013 I'd go with what your friend said. AN -10 or so, and while you're at it tap the valve cover too. It will look super clean that way. Link to comment
510T Posted April 30, 2013 Report Share Posted April 30, 2013 Tap it for an NPT fitting then you can use an AN-NPT and it will be just like the turbo oil drain. Link to comment
