Max wagon rear width?
  • Replies 8
I am currently running 15x7 +25 offset. I have some room with a rolled fender and a bulgy tire (205 R50, a few mm of bulge past the wheel itself). A 15x8 0 offset would be 1.5 inches further outboard from where mine currently are. With a little less bulge (maybe even some stretch) I think you could probably make it work.
One other thing to remember is that you're not going to have any rear camber on a wagon, so you're stuck with what you've got from that fitment perspective, no "squeezing" tire under the lip.
Tendril beat me to it with my own pics!  :rofl:
15x7 0 with a 195-50 ( I had 55's before) tire is a tight fit, but theres some room before the rim will start to hit the leafs so I'm sure you could fit a 15x8 +20 or so back there.
Also keep in mind my axle is slightly mis aligned, so one side is about 5mm further in than the other(you can see in the pics)
It all depends on how badly you really want them to fit.
I have rolled fenders, and a combination of 510 and 720 truck leafs... no blocks.
