mini&therat Posted April 18, 2013 Report Share Posted April 18, 2013 Quick question to anyone - can I easily swap in an 85 non 4x4 z24 in my 83 KC 4X4? Thanks Quote Link to comment
datzenmike Posted April 18, 2013 Report Share Posted April 18, 2013 Yes. You will need to swap the '83 4x4 oil pan and pick up tube onto the '85 engine. Also late trucks like the '85 may have had a feedback carb, so if it does you may have to swap your '83 carb on as well. Possibly the intake too. Quote Link to comment
izzo Posted April 18, 2013 Report Share Posted April 18, 2013 Yes. Tho measure the clutch, also verify the oil pan is the same. if not just swap it. Quote Link to comment
datzenmike Posted April 19, 2013 Report Share Posted April 19, 2013 2wd and 4x4 oil pans are totally different shape to clear the front differential. All Z24 motors 2 and 4wd had the 240mm clutch and flywheel. Quote Link to comment
mini&therat Posted April 19, 2013 Author Report Share Posted April 19, 2013 Best forum ever! thank you. I will update my other thread as I work on getting my truck up to better than new. Quote Link to comment
