Toney Posted March 19, 2013 Report Share Posted March 19, 2013 I am currently trying to clean up my factory harness on my 72 510, it is going to be a street rod, I only need essentials(headlights brake lights, turn signals, ignition,etc) I found a universal harness through EZ2Wire.com KW4EC - BASIC Engine/Lights Economy Harness, pretty inexpensivefor this. I think this project would go a lot easier if all the harness is knowledgable to me Also plan on using aftermarket gauges Any ratsuners that have experience with universal harnesses? Thank-tony Quote Link to comment
dennis Posted March 20, 2013 Report Share Posted March 20, 2013 I am currently trying to clean up my factory harness on my 72 510, it is going to be a street rod, I only need essentials(headlights brake lights, turn signals, ignition,etc) I found a universal harness through EZ2Wire.com KW4EC - BASIC Engine/Lights Economy Harness, pretty inexpensivefor this. I think this project would go a lot easier if all the harness is knowledgable to meAlso plan on using aftermarket gauges Any ratsuners that have experience with universal harnesses? Thank-tony I am currently working with a Summit Universal harness. All of the universal harnesses are based on American cars so it will be a little on the weird side when you install it. The 510 has many systems sharing a fuse so just make sure you map out your harness well. Almost everything you need will be behind the glove box. I am currently on the flasher/turn signal mechanism and it is proving to be a pain in the ass. Everything else is pretty easy. Quote Link to comment
freaky510 Posted March 20, 2013 Report Share Posted March 20, 2013 I used the EZwire kit on a 2dr awhile back nice kit for the price and had plenty of acc power to run everything I wanted and needed. Quote Link to comment
