chebetio510 Posted March 12, 2013 Report Share Posted March 12, 2013 so i started swapping my 4x4 leaf springs in the 620, got one side in fine, other side half is hanging, i can not remove the front bolt,,, sprayed pb blaster, wd40, ect, nothing,, the nut came off easy but the bolt itself nothing, at this point im thinkin air chissel, but then im out a bolt, can i use a standard bolt? Quote Link to comment
DeviousPsycho620 Posted March 12, 2013 Report Share Posted March 12, 2013 You can buy grade 8 bolts to replace the old ones. A standard bolt is far to weak. Quote Link to comment
Dawa Posted March 12, 2013 Report Share Posted March 12, 2013 so youve removed the nut but the bolt is still on there? if thats the case, wack the nut out with a mallet/punch or like ^ was saying, you can plan to replace and upgrade the bolts and if thats the case you can cut them out/off. Quote Link to comment
chebetio510 Posted March 12, 2013 Author Report Share Posted March 12, 2013 i been clawing away with a hammer an pb blaster tht sucker wouldnt move... gonna let it overnight. if anything im cutting it off.. its the fron eyelet on the leaf where the bed starts.. Quote Link to comment
chebetio510 Posted March 13, 2013 Author Report Share Posted March 13, 2013 Damn, so i cut off old bolt. got old leaf out, when to home deopt, looking for grade 8 bolts, in the approximate size and they have nothing... i cant seem to find anything, anyone help? the 720 bolts are different on the head... need one asap Quote Link to comment
DeviousPsycho620 Posted March 13, 2013 Report Share Posted March 13, 2013 Hardware store not home improvement store. Or call an auto parts store. Quote Link to comment
herculesinwyoming Posted March 13, 2013 Report Share Posted March 13, 2013 Ace hardware has what you need Quote Link to comment
chebetio510 Posted March 13, 2013 Author Report Share Posted March 13, 2013 do you guys know wht size i need Quote Link to comment
