transponder7 Posted February 24, 2013 Report Share Posted February 24, 2013 Hello all. I am heavily considering converting my "virgin" 1980 210 to a manual gear box and was seeking input from any and all sources. This is a longer term project, hell I don't even have a crane yet, but I'd like to know what to keep an eye out for as far as stockpiling parts and what not. Also, some words of wisdom and or success stories couldn't hurt either, I suppose. Thanks P.s. sorry if miss categorized, I'm a noob. Quote Link to comment
datzenmike Posted February 24, 2013 Report Share Posted February 24, 2013 If possible find a car that already has everything. Possibly w wreck in a yard or a crap one for sale cheap. This gives you everything at once and no small missing part to hold you up. This is likely cheaper in the long run than buying everything separate. You will need the brake and clutch peddles, possibly the complete under dash housing the holds them, the linkages and springs, bushings, clips and nuts. The clutch master cylinder and the push rod between it and the peddle. (might be a good idea to buy the master new) The clutch slave and the rubber flex line that connects it to the body. A hydraulic hard line between the master and slave. (usually best to buy a pre made brake line the same length and bend it yourself.) A 4 or 5 speed transmission and the driveshaft if different length than the automatic driveshaft you have. Must have the shifter and dust boot, clutch arm and dust boot, push rod between slave and clutch arm, release bearing collar (buy new release bearing) A flywheel A pilot bushing for the end of the crankshaft. A clutch and pressure plate. (new is good but a good used one is ok too) Quote Link to comment
transponder7 Posted February 24, 2013 Author Report Share Posted February 24, 2013 I was thinking of going the parts car route, mostly because I need/want a complete interior. I guess I'll be on the lookout for a 5 speed with a blown motor, or something like that. Are there any that will bolt right up to an a15 and chassis or do i have to be "creative"? Quote Link to comment
datzenmike Posted February 24, 2013 Report Share Posted February 24, 2013 The '79 210 five speeds were a 60 series transmission with a dogleg shift pattern. '80 and on were regular shift. Don't know about driveshaft length so get that too. Quote Link to comment
transponder7 Posted February 24, 2013 Author Report Share Posted February 24, 2013 roger wilco Quote Link to comment
chasingcarsxx Posted February 24, 2013 Report Share Posted February 24, 2013 I also have an 80 210 that's an a15 with an auto transmission and I want to convert it to a manual so very badly...does anyone know if a 1979 210 would still work if I had the whole car to pick parts from? I'm sure being creative about it will still be a factor but even as a possibility ;) Quote Link to comment
