aintnobiscuit Posted February 13, 2013 Report Share Posted February 13, 2013 Hi guys, I ordered some rear bubble flares from futofab and i believe they will be arriving in about 2 weeks. In the mean time, I have been looking up how to install them... it doesn't seem like there's a write-up so I thought I'd start asking questions and update here as I install them. I am not referring to ZG flares, I am referring to these type of flares: I know i need to position, mark and pie cut the existing fenders, bend them out and cut the tabs off. Is there a tool that works better than any other for this? I have an oxy/acetylene torch, grinder w/cut off disc and a sawz-all. Which is the preferred tool? I am assuming cut off wheel but i've seen what appear to be marks from a torch on a lot of guys fenders after they have cut out sections... so i'm not sure now. Do most people just lay fiberglass over the fenders onto the body and sand it down to keep it in place or do they rivet them in, then do the same. I am not a body guy and the most i've ever done is bang out dents, etc. So any help/pointers in this area would be appreciated. If you have pictures, that would be cool too. Anything else you can think of that I should know before starting? Post below! Thanks :) Quote Link to comment
RedBanner Posted February 13, 2013 Report Share Posted February 13, 2013 Oops thought that was the first one, brb. Quote Link to comment
RedBanner Posted February 13, 2013 Report Share Posted February 13, 2013 The rear, its the same for the bubble flares, exept you mold them in and paint it all. Quote Link to comment
RedBanner Posted February 13, 2013 Report Share Posted February 13, 2013 And its preffered to weld the inner fender not glue it. Thats probly why you have noticed burn marks. Quote Link to comment
aintnobiscuit Posted February 13, 2013 Author Report Share Posted February 13, 2013 Thanks. This is for bolt on flares though. It is useful information, and I have already watched all 9 of them to get an idea of what to do. What does everyone do with fiberglass flares though? If you look at the flares on the car image I posted above, it appears to be fiberglassed/bondo/sanded... how are they affixed to the car? Can you just lay some thin fiberglass on the fender where it meets the body, sand then paint it? That seems like it would be flimsy, which is why i asked about riveting, etc. Quote Link to comment
HudsonMC Posted February 13, 2013 Report Share Posted February 13, 2013 Many do a "minitub" in the rear with bubble flares on a 510. If you have the "how to modify" book, it's detailed in there. Here's a link to download the searchable PDF of the book from the 510 archives put together by okayfine from the 510 realm. https://docs.google.com/folder/d/0ByCvxnHNk90SLW5ZQ3kySkdIa2s/edit edit: fixed link 1 Quote Link to comment
RedBanner Posted February 13, 2013 Report Share Posted February 13, 2013 He did "mini tub it, just with adhesive, the process is the same, then you blend it I to the rest of the car and paint it. Quote Link to comment
SakuraGarage Posted February 13, 2013 Report Share Posted February 13, 2013 if your not cutting the fenders then flares are pointless unless you want to be a million feet high. Im a paint and body guy and I really hate that video of the guy doing the "SCCA" Z. For metal quarter panels just place the flares where you want them, mark them, cut a bit below your mark, hammer the inner fender out/over the outter fender (you'll want to cut the outer a bit higher than the inner) and weld them back together. Then just bolt on or mold the flares in. 1 Quote Link to comment
SakuraGarage Posted February 13, 2013 Report Share Posted February 13, 2013 this is the arch cut and the inner hammered up a bit. This is after a bit of hammering the inner over the outer a bit more hammering... (this car had a 1/2" of bondo and tons of holes on the rear fender... hopefully yours will look better under there.) I can't find a picture of it welded but you get the idea... you'll notice the gap... that wasn't a mistake, it was rusted on the back side and i trimmed it out. Start to finish this is about a 3 hour job for rears and like 20 mins fronts. Quote Link to comment
aintnobiscuit Posted February 13, 2013 Author Report Share Posted February 13, 2013 Thanks. all this does help a lot. I REALLY appreciate a link to the book, i don't mind reading to learn and do it often. I just haven't ever seen a single post about how to mold the fiberglass fenders on, so hopefully this helps someone else too. P.S. What suspension is that in the last picture? Quote Link to comment
SakuraGarage Posted February 14, 2013 Report Share Posted February 14, 2013 Thanks. all this does help a lot. I REALLY appreciate a link to the book, i don't mind reading to learn and do it often. I just haven't ever seen a single post about how to mold the fiberglass fenders on, so hopefully this helps someone else too. P.S. What suspension is that in the last picture? Its a 240sx and the coilovers are Tein super drifts. Molding in the fenders, i affix them to the body (if you have the rivet reliefs already just rivet it on and fill the reliefs) and a panel bonding adhesive like the guy in the video did. Then a thick strip of the panel bonding adhesive in the joint where the flare meets the body... let it set up and do a quick sand then cover the joint with a light weight body filler. If you are going to have to use a lot of filler to make it smooth then just lay some fiber glass over the joint/seam first. Ideally you'll want as little filler as possible or it may crack down the road. You'll put a lot of hours into sanding/shaping and its probably best to just pay some one to do it once you've cut, welded, and attached the flares. Quote Link to comment
aintnobiscuit Posted February 15, 2013 Author Report Share Posted February 15, 2013 Well, my passenger side front is pushed in a little bit. i suppose i could get it fixed at the same time... But then again.. if I'm doing all that, i might as well get the car painted... shit... ohh money, you come and go so fast. Quote Link to comment
