Stupid_fast Posted February 6, 2013 Report Share Posted February 6, 2013 Hi all, I've been messing about with my leaf springs and last time I installed them back my axle was misaligned, so the wheels where both turned a bit to the right. The stock leaf spring pads hold the alignment, but running beltech blocks they don't fit in correctly (1/2" button in a 1" hole). Even running pinion angle correctors mess with how the stock rubber fits to the axle and its tough to get aligned properly. I was wonder if anybody knows of an aftermarket leaf spring pad to properly center the axle on the leafs ?? I was looking at summit they have some for Camaro's and stuff but I don't know if they have the same 1" size knob on them. Sucks to throw off alignment every time I change springs. I know I could just pull the axle back with the u-bolts loose and make the wheels straight but it seems like a bad solution. Thanks ! Quote Link to comment
banzai510(hainz) Posted February 6, 2013 Report Share Posted February 6, 2013 MY belltech blocks fit perfect on my 521 leafs spring. I figured they would be the same hole size. this is good to know. I used 6202 the 2 deg 3inch But ran a 2 inch and it was the same also for fitting=good Quote Link to comment
Stupid_fast Posted February 6, 2013 Author Report Share Posted February 6, 2013 MY belltech blocks fit perfect on my 521 leafs spring. I figured they would be the same hole size.this is good to know. I used 6202 the 2 deg 3inch But ran a 2 inch and it was the same also for fitting=good Haha I knew you would hop right on this Hainz !! I have beltech 1" blocks, they have like a 1/2" knob on the top and do not fit 510 wagon axle properly ! Wagon axle needs like a 1" centering pin. Had to drill the bottom of those beltech to fit the axle bolt, too! I'm making a setup combining a set of 720 leafs so I won't need blocks anymore. my friend who has a KA and it getting bad axle wrap and misalignment due to the blocks was talking to me about my experimenting with combining leaf packs, he wants a setup that does not require blocks. So basicly I'm just developing this on my goon then I'm going to make a setup for his. If i just had axle pads that fit on top of those 13mm leaf center bolt, then 1" knob to align the goon axle it would be fine ... Maybe a small 1/2" or 1" block that had a 1" pin on top ?? Maybe just leave u-bolts snug, pull ebrake hard in straight line until stopped, tighten the u-bolts back up ? My current setup looks like this... has about 1" wheel gap. and it was misaligned (wheels both pointed slightly right). Quote Link to comment
