imadriftking Posted January 30, 2013 Report Share Posted January 30, 2013 Okay so my datsun Ka24e swap is giving me hell i need to know why my injectors have 12v power when key is on but doesnt pulse Quote Link to comment
imadriftking Posted January 31, 2013 Author Report Share Posted January 31, 2013 Okay so i narrowed it down to my injectors arnt getting the groun pulse from ecu plz help Quote Link to comment
Skib Posted January 31, 2013 Report Share Posted January 31, 2013 what are you using to check the pulse? Quote Link to comment
imadriftking Posted January 31, 2013 Author Report Share Posted January 31, 2013 Sound of click of injector i hav fuel rail off and just injectors pluged in they shoukd still click Quote Link to comment
imadriftking Posted January 31, 2013 Author Report Share Posted January 31, 2013 Okay also i just relized i have to run a hot to fuel pump and ecu cuz the relays wont kick on but.there good i checke them with another car the only.relay thats good is the one where.you ground datsun ign wire from other pin on relay Quote Link to comment
imadriftking Posted January 31, 2013 Author Report Share Posted January 31, 2013 Do do i have abad ground somewher i dont.think i do i got a good engine to chassis and also my harness ground is grounded on aluminum head i that fine? Quote Link to comment
philcas1987 Posted February 1, 2013 Report Share Posted February 1, 2013 usually if the edu doesn't sense the cas signal it won't run the pump or signal the injectors. Did you figure out your ignition system? You fucked up somewhere Quote Link to comment
