521 radiator?
  • Replies 4
I've also heard of running a Fiero aluminum rad too. The L20B would work as it's an L series but may be too thick. The 620s modified the rad support to fit them but ran clutch fans too. (I think) A non clutch fan like the 521 might have enough room. The L20B rads also came in 3 core to.
Here's an L20B rad support with the outward bend for room. The engine looks like an L18 or L16 without clutch fan. The 521 would be similar for space if you think it will fit.
http://i138.photobucket.com/albums/q251/datzenmike/truckradsupportL20b.jpg[/img]"]truckradsupportL20b.jpg
I'm using a scirocco radiator.
Works great. I just built a couple of angle brackets for it to set on. Bolted them to the core support.
That way the filler is the highest point of the cooling system (keeps air pockets out).
Patrick
