baasdirk Posted December 16, 2012 Report Share Posted December 16, 2012 Hey guys Does anybody have a wiring diagram for a 1970 datsun pl520/521 pickup for me. Busy with a restoration project and having some electrical issues. Thanks a lot Dirk Quote Link to comment
DanielC Posted December 16, 2012 Report Share Posted December 16, 2012 The whole system. * LIghts only. *note. This diagram does not include the wiring and two relays used with the dual point distributor. That system uses several switches on the throttle pedal, carburetor, transmission, and clutch pedal to function. If you have a truck with a five speed transmission, a weber carburetor, or a matchbox distributor, that system will not function. The dual point system was used to retard ignition timing only in third gear, part throttle. Quote Link to comment
