laotsu Posted December 21, 2012 Report Share Posted December 21, 2012 Lets not start a which coast is better rant. :geek: I was just saying that most buyers that have contacted me are on the west coast and shipping from the east coast is not cheap. Dood I was winding you up! :poke: Good luck with the sale, I totally want your engine and think it is well priced. I just wish I could buy it. Link to comment
qwik510 Posted December 21, 2012 Author Report Share Posted December 21, 2012 Dood I was winding you up! :poke: Good luck with the sale, I totally want your engine and think it is well priced. I just wish I could buy it. Thanks! It will sell after the holidays. Tell your girl she gets no presents but instead a cross country trip to Washington, DC so you can drive here and pick it up in person.. :rofl: 1 Link to comment
qwik510 Posted December 21, 2012 Author Report Share Posted December 21, 2012 So I got off my butt today and pulled the valve cover again so I could Identify the cam. It has these markings on it. Crane - DA-272-2-10-NO And on the bottom it says D 62-50-87? The 8 is very faint and the 7 is not clear so it may not be a 7 but I think it is. Jumbo pic here: http://datsun510.com/photopost/showfull.php?photo=30521 Pic: Based on how they mark their cams, it looks like it might be a 272 lift. Crane does not make Cams for Datsuns anymore and I can't find specs for it. This engine is going to be great for someone. Lots of performance goodies. Crane Cam, Centerforce Clutch, even the bolts for the valve cover are stainless. Elephant Oil Cap, and a single points dizzy too. I think the cam, clutch and dizzy are worth the price of the entire engine. I am starting to fell like I am selling it too cheap. :confused: Buy it before I change my mind. :w00t: Link to comment
qwik510 Posted December 21, 2012 Author Report Share Posted December 21, 2012 Found this cam thread on this site. http://community.ratsun.net/topic/31262-hot-cam/ It's Crane part# 162-0012 grind # DA-272-2-10 4.71 lift. Cam Card says It requires springs # 99884 and Retainer # 903-0102PART NUMBER: 162-0012 ENGINE TYPE: MECHANICAL SPECIAL GRINDNO: DA-272-2-10ENGINE IDENT: 1968-1980 DATSUN-NISSAN "L" 4 CYLINDER 1595-1952 CC SOHCVALVE SETTING: INTAKE 0.15 MMEXHAUST@ VALVE0.20 MM HOTINTAKE @ CAM LIFT: EXHAUST @ CAMCAM TIMING.254MM @ VALVE LIFTPART NUMBER7.41 MM 7.41 MMINTAKE EXHAUST11.43MM 11.43MMROCKER ARM RATIO1.541@ VALVE ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER RATIOSOPENS CLOSES ADVERTISED DURATION27 BTDC 65 ABDC 272 ° 72 BBDC 30 ATDC 282 °SPRING REQUIREMENTS DUAL OUTERRECOMMENDED RPMRANGE WITH MATCHING INNER COMPONENTSCLOSED: OPEN:TRIPLE9988490 LBS 180 LBSINTAKE EXHAUST42.1MM @ 31.4MMOPENS11 BTDC 56 BBDCOR1 21/32MINIMUM RPM MAXIMUM RPMVALVE FLOAT22005600 --LOADS:@CAM TIMING @1.0 MM VALVE LIFTCLOSES41 ABDC 6 ATDCMAX LIFT 105°ATDC115°BTDCDURATION232 ° 242 °TIMING FIGURES MEASURED AT VALVE USING ZERO LASH. RETAINER PART #903-0102 MUST BE USED WITH THE SPRINGS LISTED ABOVE. VALVE LASH CHECKED BETWEEN CAMSHAFT AND FOLLOWER. INSTALL SUPPLIED OIL PLUG. and another notable reply from the above thread Found this info on a Z car site. Seems to be the same Grind Number so maybe the same except for 4 cyl. instead of 6 cyl. ? Part Number: 168-0012Grind Number:DA-272-2-10Engine Identification:Start Yr.End Yr. Make Cyl Description1970 1984 DATSUN-NISSAN 6 GOOD IDLE, DAILY PERFORMANCE USAGE, GOOD LOW AND MID-RANGE HP, AUTOCROSS, RALLYING, 10.0 TO 11.5 COMPRESSION RATIO ADVISED. BASIC RPM 2200-5600Engine Size 2393-2753 C.C.Valve Setting: Intake 0.15 MM Exhaust 0.20 MM HOTLift: Intake @Cam 7.41 MM @Valve 11.43MM All Lifts are based on zero lash and theoretical rocker arm ratios.Exhaust @ Cam 7.41 MM @Valve 11.43MMRocker Arm Ratio 1.541Cam Timing: VALVE @.254 MMLift: Opens Closes ADV DurationIntake 27 BTDC 65 ABDC 272 °Exhaust 72 BBDC 30 ATDC 282 °Spring Requirements: Triple Dual Outer InnerPart Number 99884Loads Closed 90 LBS @ 42.1MM or 1 21/32Open 180 LBS @ 31.4MMRecommended RPM range with matching componentsMinimum RPM 2200Maximum RPM 5600Valve Float --Cam Timing: VALVE @1.0 MMLift: Opens Closes Max Lift DurationIntake 11 BTDC 41 ABDC 105 232 °Exhaust 56 BBDC 6 ATDC 115 242 ° Link to comment
qwik510 Posted December 21, 2012 Author Report Share Posted December 21, 2012 Sale Pending Link to comment
laotsu Posted December 21, 2012 Report Share Posted December 21, 2012 lucky buyer, looks like a lotta nice stuff on that engine. Link to comment
Work280 Posted January 17, 2013 Report Share Posted January 17, 2013 Is the engine sold?? If not let me know I need a engine mine just gave up Link to comment
qwik510 Posted January 17, 2013 Author Report Share Posted January 17, 2013 I still have the engine. I got tired of getting shipping quotes for people that thought it might only be $100 -$150 to ship it from the east coast to the west coast. Shipping to West coast was quoted at $450 to the terminal. You would go pick it up there. They would load it into your pickup. I will charge $50 to strap it to a pallet, shrink wrap it, load it into my pickup, drive it to the nearest terminal to drop it off (45 minutes each way) I figure I can just keep it as a spare. They seem to be in high demand. If anyone really wants it, figure $950 shipped to the west coast. $900 to other locations west of the rocky mountains, $850 to other locations east of the Mississippi I figure I can just wait for a local buyer or keep it as a spare. They seem to be in high demand. Link to comment
Work280 Posted January 17, 2013 Report Share Posted January 17, 2013 Please pm me I will take it Link to comment
wagoon Posted January 17, 2013 Report Share Posted January 17, 2013 I would take this in a heart beat if you were closer. Hope someone buys this, this is a nice set up. $900 for a decent built motor for a West sider Rider is not bad, but than again rethinking Rebello or Troy Ermish motors...those are off the chain...but pricey. Link to comment
qwik510 Posted January 17, 2013 Author Report Share Posted January 17, 2013 This Engine is SOLD! 1 Link to comment
