SOLD! MOD PLEASE DELETE, THX
$1000 obo (trade see below)
Seattle, WA. 'merica
1974 corona
runs, drives and stops
50k ish miles on chassis
all trim and my corona parts stash included + extras
sat for a VERY long time outside, then was spray painted 8yrs ago...not so good now
very few dents, normal rust (front of rockers/rear wheel well lips)
bad crack in original windshield all other glass is good
almost untouched wiring/body
mods:
4/3 drop, cut hilux springs/blocks newish shocks
84+ 22R, weber 32/36
dt 4-1 header 2in exhaust
81 celica 5speed, a W50 i think, but whatever was in a 81
SACHS clutch, turned flywheel 5-10k ago
81 celica 2 part driveline with home made xmem
96 saturn SC1 90amp alt
complete 5 speed swap with factory parts, new master/slave 2yrs ago
electronic ignition
78 corona wagon tailgate with wiper/harness, factory switch
powder coated chrome hood louvers
speed bleeders (1way valve) in all 4 brakes
the bad:
needs a windshield and window seals
carpet is destroyed/missing
cracks on dash, holes in seats
small cut on the tunnel for the shifter
carb is F'd, runs but wont idle.
electrical is funky, works but has moods.
it sat for a good 25 years outside
loud top end on motor
radiator very functional but mounted ghetto
needs tires
front brakes/master replaced, rear has needs but work
but wait there's more:
perfect front bumper
roof rack w/slats
auto brake pedal/shifter
auto and manual center consoles
87 truck carb and intake w/emissions setup totally functional...
3/4 original hub caps on close enough to stock 81 celica wheels
lots of new brake and suspension bits ive replaced along the way but cant call new.
and more random corona parts i havent dug out, pics of everything to come.
local delivery
this is a project car, it needs some work im not trying to hide it. would like to see it to a good home and will have tons of current pics and video very soon. i have a complete build thread on it from day 1...
here:
http://blacksheepauto.com/forum2/index.php?topic=77.0"]http://blacksheepaut....php?topic=77.0 warning: lots of pics
a couple old pics
current...more asap
things id trade for:
honda 50cc most anything bike/atv functional w/title
35/13+/15 wheeler tires
yota 2wd air bag stuffs
cash
HD projector
8ch+ mixing board
synth's/drum machines/samplers
and if your still reading... thx.
this is the quick sale listing, if no cash in my hand by next weekend sometime its going on ebay no reserve
  • Replies 3
more pics!
note: all the wheels are 14x5.5 stock 2nd gen celica steelies, rears are painted black and look smaller. all tires are old, that why it needs tires. they do hold air with not much dry rot. standard 4x114.5 lug pattern.
drivers side hub caps are original with a 1 extra in back, passenger side is 78+ corona
as i stated above, it does come with powdercoated chrome louvers in the hood (not installed yet) does not come with the original hood that was crunched, current hood is straight as can be.
WILL NOT COME WITH COLLECTOR PLATE OR LICENSE PLATE FRAME!!!!!
lots more parts to add to this pile tomorrow, and a complete list of em.
stock 87 22r carb/manifold/egr in the box with all the emissions crap cept the air box, all functional.
also note the rust hole in the floor, caused by a leaky windshield, similar hole on pass side
mileage is off by -5-10k, speedo didnt work before, does now but is off, reads fast.
radiator DOES NOT LEAK! but the radiator arms are 70% not attached, radiator is mounted solid with lots of safety wire. this motor/trans was built from spare parts i have lying around...
problems with carb:
needs adapter plate gaskets (sealed with copper spray not rtv)
primary carb shaft stripped on the nut, did the best ghetto fix i could, but still leaks (vac). also there is no choke, PO broke the bolts to the choke and bent the choke butterfly shaft with a ghetto manual setup. i have removed the choke shaft and butterflys.
questions? pic requests?
more pics, parts and info tomorrow, thanks for looking
I may of sent you a cust from so cal , mine is also for sale but came back 1976 needs smog Ca. bullshit so post yours in LA and this guy will hit you up ! 1975 and older exempt for smog shit ,I want to fix mine and paint silver and take to Toyo fest in May.
ive got it posted on JNC and a few other sites, send dude a link... and thx in advance
i am willing to ship this car, expect $1k ish to the east coast or so
as promised more pics of parts included and a list.
semi complete list of stuff included:
totally functional emissions friendly 87 truck carb and intake with all the fixins
perfect front bumper w/bumper guards
roof rack w/slats
auto (tan) and manual (grey) center consoles
glove box in grey
all missing exterior trim
complete steering column w/delay wiper switch and all ignition stuff w/key
3in drop cut hilux springs
perfect but needs paint trim panel thingy behind the front bumper
non electric black front seatbelt set
grey and black steering column covers, i think i have lost the original brown one
78 gauge cluster panel
78 grill and 1 headlight surround
auto brake pedal w/bracket n shifter
unmodified gas pedal
and the louvers, need some polish
may be a few more things floating around, i am a horder...
