datsun77 Posted June 17, 2008 Report Share Posted June 17, 2008 has anyone on here ever used a 720 bed on their 620 truck? and will the bench seat from a 720 work in a 620? Quote Link to comment
datzenmike Posted June 17, 2008 Report Share Posted June 17, 2008 The boxes come in two sizes reg cab and reg cab long. (the reg cab box also fits the KingCab model) The 720s are the same bolt pattern as the 620s. So as long as both trucks are reg cab/KingCab OR reg cab long they should swap. The '85 has separate turn signal bulbs where as the 620 shares the brake light bulbs. The 720 also has the gas tank mounted to the frame where as the 620 is mounted to the box. Quote Link to comment
datsun77 Posted June 17, 2008 Author Report Share Posted June 17, 2008 thanks alot for the info datzen mike Quote Link to comment
datzenmike Posted June 18, 2008 Report Share Posted June 18, 2008 The 720 bench is slightly wider, might work. Quote Link to comment
