SlammedSunny Posted November 24, 2012 Report Share Posted November 24, 2012 Im gathering parts for my KA24E swap and need to replace the electronic speed sensor with a manual one, I cant seem to find any online at all so I turn to Ratsun for one. At this point I dont care or even know what color of gear i need, Im more interested in finding a housing first. Paypal is the only way i will pay. Link to comment
ggzilla Posted November 24, 2012 Report Share Posted November 24, 2012 $50 from Nissan for a truck gear & housing. Your choice of gears. Link to comment
SlammedSunny Posted November 24, 2012 Author Report Share Posted November 24, 2012 do you happen to have a part number? I have yet to find an online nissan parts catalogue that is somewhat decent Link to comment
datzenmike Posted November 24, 2012 Report Share Posted November 24, 2012 For '76 B-210? 4 speed originally? Let me know and I can try and find out the number of teeth and then you can get one that will fit your 71C. Do you have the exact build date??? Probably a 3.70 rear ratio and the most common is the 17 tooth. A pinion assembly for a post '80 71B that will fit the 71C is 32702-58S17 (there is a alternate number 32702-E9817) Link to comment
SlammedSunny Posted November 24, 2012 Author Report Share Posted November 24, 2012 76 B210 with an auto orginally, but if you need to know it will have an H165 out of an 81 510 wagon in it. and 71C is the transmission? Sorry for the lack of knowledge but I am originally a Honda guy, I converted :) never turning back Link to comment
datzenmike Posted November 24, 2012 Report Share Posted November 24, 2012 Sorry for the lack of knowledge but I am originally a Honda guy, I converted :) never turning back I like where this is going..... Geeeez '81 A10 goon. Well std. and auto used the same 3.364 ratio. Well it still looks like a 17 or 16 tooth. The A10 used a larger tire than the B-210 so even though the ratios are different maybe this makes them equal. Link to comment
ggzilla Posted November 24, 2012 Report Share Posted November 24, 2012 Assuming you have the original size tires ... which make a difference to the speedometer gear. Link to comment
SlammedSunny Posted November 24, 2012 Author Report Share Posted November 24, 2012 I will be running 15x7, 195/50-R15 up front, and 15x8, 205350-R15 in the rear, what I have now is irrellivant as this will all be installed at the same time, Thanks for all the help, I have dealt with my local nissan dealer before and without a part number they are baisically useless Edit: I also want to make sure i have the tab that hold it in place, would that be included with that part number or is it seperate? Link to comment
datzenmike Posted November 24, 2012 Report Share Posted November 24, 2012 Oh wow way too many variables. Yes the dealers today don't know how to think If you have the tab from the speed sensor this will work. If you just want to get the speedometer working (though likely inaccurate) any 71-B five speed after '80 and before '86 should have the pinion type you need. Link to comment
