dozenhundred Posted November 6, 2012 Report Share Posted November 6, 2012 My 73 1200 had the light up wiper switch but not the headlight switch, so I bought one from another car and installed it. Then I found some of the newer knobs on ebay with the pictures on them instead of just text. Turns out they don't seem to instal the same. The original had a spring loaded slotted disc on the back that you push and twist to instal. The newer ones don't have the spring thingy. What holds these ones on? Is the switch different? I also bought the 620 intermittent switch off ebay, but whoever pulled it from the truck just yanked the knob off and broke off the little ears that hold the knob, so I have to do something different there anyway, maybe glue them on. Any suggestions? Thanks all. Quote Link to comment
ggzilla Posted November 6, 2012 Report Share Posted November 6, 2012 1971 1200: Pictographs 1972 1200: Text required by government 1973 1200: Lighted knobs required by government Just so no to excessive regulation and whichever you want. Quote Link to comment
ggzilla Posted November 6, 2012 Report Share Posted November 6, 2012 For the broken wiper switch, drill a hole through the shaft and fit a small pin to replace the broken nubs. To make intermittent work, get a intermittent box from 210, Z or Sentra and wire it up, it's pretty easy. Quote Link to comment
dozenhundred Posted November 6, 2012 Author Report Share Posted November 6, 2012 Thanks for that. The knobs I bought have the pictorgrams like the wiper knob in the first pic, but are the green light up variety. Drilling and pinning the damaged switch would likely block the fiber optic function. I will have to look at it closer. I am building my own acjustable delay box from a schematic I found on-line. The electrical part I can do. Just don't know how the knobs attach on the newer switches. I will try and get a pic of the back side to clarify. Quote Link to comment
ggzilla Posted November 6, 2012 Report Share Posted November 6, 2012 Those are JDM or EURO switch knobs. USA regulation required text label. FMVSS 101 Passenger Cars (Effective 1-1-72)...All manually operated controls must be identified by words As expected they reversed that decision in 1980, requiring a symbol. Japan-market Datsun 1200 continued to use symbol Quote Link to comment
