14x7 centerline style wheels $150 obo
not sure if theyre real centerlines or knock offs but they are 14x7's with low offset (looks close to 0) too low for a stock fender 4 door dime. haven't tried 'em on roldy but I'd bet the offset is perfect for s30's based off how they fit Jr.
They are currently sprayed black with plastidip but that is EASILY removable. The layer of plastidip isnt perfect. but the surface underneath needs refinishing. like I said $150 obo, rims are located in the bay area and will come with no tires, I can include a set of mis-matched roller tires but the tread is worn to maybe 25% and they wont be mounted...
I found a diesel 720 close by thats pretty cheap...help fund a datsun buy lol
also check out my sig, I'm also selling a wiring harness and ECU for a KA24e swap
edit: I should be able to include a set of lugnuts if necessary but they're pretty standard mag lugs
  • Replies 7
I also have some slot mags in good not perfect condition, need polishing really. Low offset as well, again, good for s30's or flared dimes. I'll get pics as soon as I can. These do have tires mounted but the rubber is dry and they are old, I'd use them for rollers or burnout rubber (why I still have these frankly) these are 14x6's im pretty sure (might also be 7's) and I'm asking $200 obo for these (they are in better shape than the centerlines and have tires)
  • 3 weeks later...
  • 1 month later...
  • 1 month later...
