downsouthnc Posted October 28, 2012 Report Share Posted October 28, 2012 iam looking for the wire that goes from the sending unit to the 3 prong conector next to the fuel pump.. this is the thing that tells you how much gas you have... thanks Quote Link to comment
datzenmike Posted October 28, 2012 Report Share Posted October 28, 2012 That is soldered directly to the sender. If yours is off, drop the tank and/or just remove the sender if you can get at it from in the car and tin and solder it back on. I've seen other sender wires and the brass terminals just corrode away and fall off so there may not be much left to solder to. If that's the case it will need replacing. Quote Link to comment
