supercrawler Posted October 14, 2012 Report Share Posted October 14, 2012 Whice one is right drain hole? Please,, someone can explain. Quote Link to comment
supercrawler Posted October 14, 2012 Author Report Share Posted October 14, 2012 Quote Link to comment
datzenmike Posted October 14, 2012 Report Share Posted October 14, 2012 H ah ha it's on the front half on the other side. See the dark oily area on the front case half? There's a vertical casting line and about half way down looks like a number 8 lying on it's side? Well the front part is the fill hole with a bung in it. Here's another dogleg, driver's side. About half way down the side and just to the rear of the bell. There's a square headed bung for the oil fill. I know it looks like a drain at the back but it isn't. What it is, is an internal shift linkage part that allows 4th gear to be above 5th. The two other things on the side of the case are switches. The top one is the reverse lamp switch, the bottom one is the 'top gear' switch for emissions control. . Quote Link to comment
supercrawler Posted October 15, 2012 Author Report Share Posted October 15, 2012 Thanks for your replied. As you said it on the other side. This is why I love this forum. Quote Link to comment
