wayno Posted December 22, 2012 Report Share Posted December 22, 2012 just an update for anyone whos interested. ive used the 240mm flywheel with new clutch kit. the new gearbox and ive used the original t/o bearing collar from the 225mm flywheel combo. what i did to remedy the problem was i packed 3 washers on the pivot point. problem solved. thanks for all your help guys. It's good that it is fixed, now it's time to enjoy your efforts. :D Quote Link to comment
Bambam91 Posted December 22, 2012 Author Report Share Posted December 22, 2012 It's good that it is fixed, now it's time to enjoy your efforts. :D found that i now have a pin hole in the radiator.. new one on the way though :) Quote Link to comment
wayno Posted December 22, 2012 Report Share Posted December 22, 2012 found that i now have a pin hole in the radiator.. new one on the way though :) If it is just a pin hole, loosen the radiator cap so it doesn't build pressure, should be fine till you get the new radiator, but keep your eye on the water level, don't let it get low. Quote Link to comment
