67_1600 Posted October 9, 2012 Report Share Posted October 9, 2012 I'm at a yard trying to remove the seatback part of the rear seat but can't see exactly how to do it. I did try searching but didn't see anything. Any help would be appreciated. Quote Link to comment
Guest 510kamikazifreak Posted October 9, 2012 Report Share Posted October 9, 2012 The pivot should be held on with 4 bolts(12 mm socket/wrench size if memory serves) Quote Link to comment
67_1600 Posted October 9, 2012 Author Report Share Posted October 9, 2012 Thanks, got it. There are 2 larger screws on each side you can get to when it's folded down. Thanks again. Quote Link to comment
Laecaon Posted October 9, 2012 Report Share Posted October 9, 2012 You can also just undo 1 side. Then slide the seat out. I had to do that as a screw got stripped out. Quote Link to comment
67_1600 Posted October 9, 2012 Author Report Share Posted October 9, 2012 Thanks for the tip - I actually thought I was going to end up stripping one but I finally got it. Quote Link to comment
