Nissan.aka.foreign.chevy Posted October 6, 2012 Report Share Posted October 6, 2012 hi, i have an 85 nissan 720. recently ive hade troubles starting it. i turn the key, but it doesnt crank, all my dummy lights turn on and the front relay (above my fuse block) clicks. when this started, id slam my door a couple times.. and boom it worked no problem (weird). i replaced the relay and it worked for about 2 days w/out any problem, then same problem so i replaced it again and still nothing. itll work randomly but wont fire now either. i was just push starting it but now even that wont work. PLEASE HELP!!! IN DESPERATE NEED OF AN ANSWER!!!!! Quote Link to comment
banzai510(hainz) Posted October 7, 2012 Report Share Posted October 7, 2012 I had this happen to my 521 I dont know if related to tyours proplem. the wire in the starter selinoid felt fine but wasnt making a good contack. I got a wire put it on the + battery then put the other end right on the starter selinod. if it cranks good then its just a loose connecter that maybe needs to get sqeezed with a pliers. Or a key switch that is dropping to much voltage. I put the key to on and use the wire MY TRUCK would then run. I fixed but putting pliers on the connctor if you put the 12volt wire from battery on the selioniod and nothing happens DONT TURNOVER I say swap the starter. But on just rpuble shooting form the chain here and I am not a 720 expert. Im just going by NOT CRANKING!!!!!!!!!!! Quote Link to comment
