FricFrac Posted September 13, 2012 Report Share Posted September 13, 2012 Looking for a NAPS Z24i dizzy with the built in CAS. As far as I can tell it comes from the 1986-1990 Pathfinder or Hardbody but the one's I found didn't have the CAS. Doing a Mega Squirt NAPS Z2.2 build/conversion.... Thanks! Link to comment
Sealik Posted September 14, 2012 Report Share Posted September 14, 2012 I might have one....will go have a look You are going to 'document' this Mega Squirt NAPS Z2.2 build/conversion???..... :D This is going in your 510? Link to comment
datzenmike Posted September 14, 2012 Report Share Posted September 14, 2012 The Z24i CAS dizzy was found in the April '85 and up 720, '86.5- '89 D-21 Hardbody and the '87-'89 WD-21 Pathfinder. It was also on the Vanette..... good luck finding one of those. Link to comment
Sealik Posted September 14, 2012 Report Share Posted September 14, 2012 Here it is... Zero play in shaft...would clean up as new Pretty sure it's the Z24i dizzy.....Mike could probably confirm PN numbers D4P84 04 B8803 22100 07G01 http://www.rockauto.....php?pk=1123511 Link to comment
datzenmike Posted September 14, 2012 Report Share Posted September 14, 2012 03 '88 to 08 '89 Hardbody or Pathfinder Z24i. Link to comment
FricFrac Posted September 14, 2012 Author Report Share Posted September 14, 2012 I might have one....will go have a look You are going to 'document' this Mega Squirt NAPS Z2.2 build/conversion???..... :D This is going in your 510? I'll photo doc it as I go. I've got the misc stripped off the block right now getting ready to rebuild the engine. Yes - it's going into the 510 :) Wanted to do something a little different without a lot of modding to get it in. I think the NAPS Z head will be good for a boosted application. It will be interesting to see if it responds to water/methanol like the L series does. Anyone have a timing curve for a Z22? Link to comment
FricFrac Posted September 14, 2012 Author Report Share Posted September 14, 2012 Here it is... Zero play in shaft...would clean up as new Pretty sure it's the Z24i dizzy.....Mike could probably confirm PN numbers D4P84 04 B8803 22100 07G01 http://www.rockauto.....php?pk=1123511 Cool - have the oil pump shaft for it as well? Is it running the splined coupler? Pics of the plug for the CAS? Pics of the optical wheel? Optical wheel diameter? Link to comment
FricFrac Posted September 14, 2012 Author Report Share Posted September 14, 2012 03 '88 to 08 '89 Hardbody or Pathfinder Z24i. The late '80's Hardbody I found had no CAS in the dizzy but it was throttle body injection. It was the four plug version. Link to comment
datzenmike Posted September 14, 2012 Report Share Posted September 14, 2012 The drive spindle for the Z24i and the KA24E are the same so no worries there. Both have the splined dizzy end... . Link to comment
datzenmike Posted September 14, 2012 Report Share Posted September 14, 2012 The late '80's Hardbody I found had no CAS in the dizzy but it was throttle body injection. It was the four plug version. Maybe it was removed. It should have it. Link to comment
Sealik Posted September 14, 2012 Report Share Posted September 14, 2012 Anyone have a timing curve for a Z22? Timing curve?....cover? Cool - have the oil pump shaft for it as well? Is it running the splined coupler? Pics of the plug for the CAS? Pics of the optical wheel? Optical wheel diameter? No shaft...has the splined coupler. No plug.... clipped off as per pic. Diameter of wheel 2.120" Link to comment
FricFrac Posted September 15, 2012 Author Report Share Posted September 15, 2012 Cool thanks for the pics - that is the same size as the 280ZX optical wheel (as opposed to the 240SX). I've got a prototype optical wheel cut on the water jet that will drop right in. Is this a four or eight wire cap that goes with the dizzy? Link to comment
Sealik Posted September 15, 2012 Report Share Posted September 15, 2012 Is this a four or eight wire cap that goes with the dizzy? 8 wire.... Link to comment
FricFrac Posted September 15, 2012 Author Report Share Posted September 15, 2012 Maybe it was removed. It should have it. I know I was puzzled as well. I'd post a pic but Photobucket is misbehaving. I posted a pic in the 510 realm thread. http://www.the510realm.com/download/file.php?id=25437 Link to comment
