SHORTDOG Posted July 27, 2012 Report Share Posted July 27, 2012 Okay Guys, I am planning on adding on power steering (out of an ST model) to my 720 but my current steering box has a little play in it. My question is: Should i have my current steering box rebuilt? or does my current steering box get swapped out anyways when i install the power steering unit? :confused: Quote Link to comment
Alec 720 Posted July 27, 2012 Report Share Posted July 27, 2012 You will need to get your Steering box swapped out anyways. Because the Power steering Box is different then the non-power steering. The actual "power steering" is done in the steering box. Quote Link to comment
datzenmike Posted July 27, 2012 Report Share Posted July 27, 2012 What he said. Quote Link to comment
SHORTDOG Posted July 27, 2012 Author Report Share Posted July 27, 2012 Cool! Thanks guys, now lets just hope the unit i get doesn't end up having alot of play in it. Quote Link to comment
datzenmike Posted July 27, 2012 Report Share Posted July 27, 2012 Some of the play can be removed by adjusting it. By far the biggest cause is wear in the idler arm and tie rod ends. Just 1/8" of slack accumulated in all the steering components is magnified by the 19 to 1 ratio of the steering gears and will add up to over 2 1/3" of slop in the steering wheel. Improperly adjusted wheel bearings can also add to this. 1 Quote Link to comment
