oDufffODramAo Posted July 22, 2012 Report Share Posted July 22, 2012 Anyone know which other rotors I can use on my 510? I'd like to use 300zx rotors because I heard they fit, but I'm not too sure. Quote Link to comment
hobbes_the_cat Posted July 22, 2012 Report Share Posted July 22, 2012 You need to swap to different struts/spindles to swap on most other nissan rotors (the 280zx and 200sx struts/brakes are common swaps). I think there are some aftermarket big brake kits for the 510 strut tho if you want to spend the money. Quote Link to comment
Ratwagon1600 Posted July 22, 2012 Report Share Posted July 22, 2012 My brake setup which has now gone into the goon as follows. 180B (610) goon struts (they had the larger stub axle/spindle). I'm pretty sure the 180B SSS sedan was the same. Mitsubishi verada rotors. 180B goon hubs. VT Holden Commodore twin piston calipers. I think you are importing these and rebadging them as Cheverolet. 6mm spacers to get the caliper/rotor offset correct. Inserts and coil springs of your choosing. There are a lot of different conversions you can do, the search function and Google are your friend. A couple of Aussie websites which may give you some further info. www.bmsc.com.au www.ozdat.com www.datsport.com www.datnet.org Cheers Jason Quote Link to comment
oDufffODramAo Posted September 4, 2012 Author Report Share Posted September 4, 2012 I'm really late. Thank's for the help guys! Quote Link to comment
