JoeR Posted July 20, 2012 Report Share Posted July 20, 2012 I will be replacing by badly worn ball joints pretty soon. Any other comments/suggestions about anything else that I should replace while I'm at it? Quote Link to comment
poor-mans-720 Posted July 20, 2012 Report Share Posted July 20, 2012 Your tie rod end links are good to replace if you have sloppy steering. Also sway bar endlinks. And tension bar bushings... Anything and everything under there that looks like a worn or cracked rubber bushing really... When my truck hit the 300k mile mark I had to do this... And instead, I just did a solid axle swap... Lol. Quote Link to comment
datzenmike Posted July 20, 2012 Report Share Posted July 20, 2012 Check the idler arm too. Forget polly bushings get rubber. No vehicle needs them. Quote Link to comment
