onekickkawi Posted July 13, 2012 Report Share Posted July 13, 2012 Is there any way to fix the door latch? the door doesn't close anymore. I took off the striker and pushed it in to the latch cam by hand and it doesn't lock. Can it be fixed or do I just have to hunt for used one? Quote Link to comment
onekickkawi Posted July 13, 2012 Author Report Share Posted July 13, 2012 At work and cant take a pic... the latch and striker are the same on all though I thought Quote Link to comment
yenpit Posted July 18, 2012 Report Share Posted July 18, 2012 The latch is basically spring loaded, so you would have to remove it to check it out. If it looks good, soak it in gasoline, carb cleaner or something, grease the crap out of it, and keep "working it" until it loosens up. Otherwise, I've got good USED ones, and RECONDITIONED ones (sandblasted & re-plated in the yellow chromate). PM me if interested! Do you have a 2 door or 4 door? Quote Link to comment
onekickkawi Posted July 18, 2012 Author Report Share Posted July 18, 2012 I will try this...yenpit - check you pm Quote Link to comment
