pondking Posted July 3, 2012 Report Share Posted July 3, 2012 Do I have to cut the doors to take the windows out? Quote Link to comment
Laecaon Posted July 3, 2012 Report Share Posted July 3, 2012 No. Though its not super easy. Quote Link to comment
ggzilla Posted July 3, 2012 Report Share Posted July 3, 2012 The doors never need to be cut. Just unbolt the window track. Quote Link to comment
pondking Posted July 3, 2012 Author Report Share Posted July 3, 2012 do i slide the window out without the metal bracket attached? Quote Link to comment
ggzilla Posted July 3, 2012 Report Share Posted July 3, 2012 The window bracket stays attached. You have to unbolt the regulator and slip it out first. Maybe even unbolt the sliding track at the bottom. Quote Link to comment
Laecaon Posted July 3, 2012 Report Share Posted July 3, 2012 Undo the clips that attach it the the window regulator. Dont touch the frames like mentioned above. Now you will just have to play with it to get the windows out. Rear windows are harder than the fronts. Why do you need the window out? Are you sure it needs to come out? I can do this without any tools. Clips come off with finger pressure. Quote Link to comment
pondking Posted July 3, 2012 Author Report Share Posted July 3, 2012 i want them painted with quality i kind of gave up on the 1/4 windows Quote Link to comment
Laecaon Posted July 3, 2012 Report Share Posted July 3, 2012 Yea, I dont recommend taking those out. Its a danger to the seals. Just do a really good job at masking. Quote Link to comment
pondking Posted July 4, 2012 Author Report Share Posted July 4, 2012 the thing is i cut the rubber already so i am guessing i have no choice but to continue but I was able to take apart one of the doors thanks for the help (i was scared of continuing taking it apart) And another question how do you take the rotten squegies?? (the chrome piece with the rubber) Quote Link to comment
pondking Posted July 4, 2012 Author Report Share Posted July 4, 2012 thanks for the responds now to tackle the 1/4 windows Quote Link to comment
Laecaon Posted July 5, 2012 Report Share Posted July 5, 2012 Once you have the chrome piece off the door, you will see that the rubber is held on by a bunch of staples. Remove the staples and remove the rubber. You new rubber kit should come with clips to hold the rubber to the chrome piece. If you need to figure out how to get the chrome off, it just pulls up, be careful not to bend it, work in sections if you must. Quote Link to comment
pondking Posted July 6, 2012 Author Report Share Posted July 6, 2012 got em off thanks i actually started with the staples but realized they just snap off just worried about the 1/4 windows guessing i need to cut a lot of rubber Quote Link to comment
ggzilla Posted July 6, 2012 Report Share Posted July 6, 2012 Why cut the rubber? Just work it out. Of course you can buy new rubber from overseas, it's much easier to cut the rubber than work it out. Quote Link to comment
Laecaon Posted July 6, 2012 Report Share Posted July 6, 2012 You dont need to cut the 1/4 window rubber... Have you looked at availability/cost of those particular rubber pieces? Quote Link to comment
ggzilla Posted July 6, 2012 Report Share Posted July 6, 2012 Yes, they are about $100 and available on eBay. Dunno if the sell the rear quarters. Quote Link to comment
Laecaon Posted July 6, 2012 Report Share Posted July 6, 2012 The quarters are what I was specifically talking about. Those are on par with cargo windows on a wagon or the rear windshield on a wagon. Quote Link to comment
