Eagle_Adam Posted June 29, 2012 Report Share Posted June 29, 2012 i redoing the breaks all the way around on my truck. Im in the middle of ordering parts and i have a few questions; Its a 1974 620 with drums on all 4 corners, im intending these breaks to last me until i can start the process of buying/installing disc breaks. Q 1. i see there is a difference between right and left Wheel Cylinders BUT i don't see an indication as to whether or not the rears are different from left to right. Q 2. are there any bearing company's that you would NOT buy from. Currently i have timken bearings chosen. Q 3. i believe one of the adjusters on the rear breaks is frozen, where can i find new ones other than egay at 120 per set -.- Im sure ill have more questions but for now this is it. As always thanx for your help! Quote Link to comment
Guest Rick-rat Posted June 29, 2012 Report Share Posted June 29, 2012 You should be able to get the adjuster apart and clean it up, if not or damage it while trying to take it apart . Rockauto parts should have new adjusters, I think the rear wheel cylinders are the same on each side Quote Link to comment
datsunaholic Posted June 29, 2012 Report Share Posted June 29, 2012 A1: Rears are identical. You can get fronts that are universal as well, however the originals were keyed for one side only. A2: All bearings are Chinese now, but if you can find old-stock NSK Japanese ones you'll be ahead. A3: Someone should have the part number for the adjusters, but my Mom bought them at rockauto and they weren't that expensive. However, they are easily fixed unless damaged. Once you get them apart clean them and coat the inside with anti-sieze Quote Link to comment
Eagle_Adam Posted June 29, 2012 Author Report Share Posted June 29, 2012 You should be able to get the adjuster apart and clean it up, if not or damage it while trying to take it apart . good to hear, ill give it a go b4 i buy new ones Rockauto parts should have new adjusters I looked and couldn't find them. Ill look again think the rear wheel cylinders are the same on each side sweet! thanx Rick-Rat A1: Rears are identical. You can get fronts that are universal as well, however the originals were keyed for one side only. A2: All bearings are Chinese now, but if you can find old-stock NSK Japanese ones you'll be ahead. A3: Someone should have the part number for the adjusters, but my Mom bought them at rockauto and they weren't that expensive. However, they are easily fixed unless damaged. Once you get them apart clean them and coat the inside with anti-sieze thanx for the info datsunaholic! ill keep looking for adjust in case i cant repair the frozen one Quote Link to comment
Guest Rick-rat Posted June 29, 2012 Report Share Posted June 29, 2012 The adjusters are in the brake section under miscellanious at Rockauto R/side 0850032 L/side 0850024 Quote Link to comment
Eagle_Adam Posted June 29, 2012 Author Report Share Posted June 29, 2012 The adjusters are in the brake section under miscellanious at Rockauto Thank you! i even searched adjusters and it came up with nothing -.- Quote Link to comment
