ddrum Posted June 15, 2012 Report Share Posted June 15, 2012 As i was taking off the old rod bearings from the piston rods, I found some wear on the rod oil hole. Has anyone seen this before? Is it common? Quote Link to comment
datzenmike Posted June 15, 2012 Report Share Posted June 15, 2012 There can't be any wear in this area as the bearing covers it. I just happen to have a random Z24 rod beside my computer so I took an oic of it. Looks like they all have this feature... The only reason I can see for this chamfered edge around the hole it to make it larger under the bearing hole area above it. So if the bearing oil hole is slightly off center it will still be over the larger hole beneath it. Quote Link to comment
ddrum Posted June 15, 2012 Author Report Share Posted June 15, 2012 they look different on each rod... L20b by the way Quote Link to comment
ddrum Posted June 15, 2012 Author Report Share Posted June 15, 2012 double post fail haha Quote Link to comment
datsunaholic Posted June 15, 2012 Report Share Posted June 15, 2012 It's not "wear" as much as erosion. It seems to correspond with the hole in the bearing backing plate. Not a big deal. Quote Link to comment
ddrum Posted June 15, 2012 Author Report Share Posted June 15, 2012 Cool, good to know thanks a lot datsunaholic and Datzenmike. Quote Link to comment
