L20B Wiring Problem
I have an L20B that was a basket case a month ago. I'm down to wires and hoses. There are 5 wires I'm having trouble figuring out. They are Red, White, Blue, Black with Blue Stripe, and Black. Some are spade, other bullets. I know two of them go to the solenoids on the Carb. And I think one goes on the side of the Distributor (points non Cali) that sends power to the capacitor. And maybe one goes to the spade on the distributor bolt (a ground?). And the last one possibly went to the A/C that is no longer there. Can anyone help me put these in the right spots? Electronics are my weakness.
  • Replies 9
I think I got it. Red on anti-diesel solenoid, White on other solenoid, Black/Blue on dist. And the other two were hanging for A/C I think. Doesn't matter. I hooked it all up and it had seemed fine. Splash of gas in the carb and it started running down the exhaust from between the two manifolds. That's twice I've had to stop my project because of the stupid combo manifolds. If I can't find some manifolds for cheap, off to the scrapyard.
The spade under the cap goes to Coil- terminal
The one near the vacuum advance unit under a bolt should be onnected to a ground wire (black wire).
By the way, the 1977-1978 distributors that I've seen have two wires out the side (red & green).. What is the part number on the side (should be 22100- something)? Brush off dust/grime to read the number.
Thanks. And the multi wire are Cali spec only.
