rad510 Posted June 8, 2012 Report Share Posted June 8, 2012 when you crank and there no fuel is not coming out of fuel hose is that a bad fuel pump and i dont even hear the fuel pump turn on too.. Quote Link to comment
dennis Posted June 8, 2012 Report Share Posted June 8, 2012 wow, this question is too vague and you should have at least posted this in the 510 section. Is this an L series engine? Do you have an electric fuel pump? If this is the stock fuel pump you will not hear it turn on because it is mechanical. It will be located on the head on the passenger side of the car. 1. Do you have fuel in your tank? I dont care if your gauge says you have a full tank, do you have fuel in it? 2. When is the last time you changed your fuel filter? The stock mechanical fuel pump is reliable and very rarely goes out. if you have no fuel at the filter (behind the passenger side headlights, if you are stock)then it is most likely a bad fuel pump. Quote Link to comment
rad510 Posted June 8, 2012 Author Report Share Posted June 8, 2012 ok my motor is a datsun 200sx z20e napz it like a L series motor too... and i think its still have a stock datsun 510 fuel pump ...i change the fuel filter alread .. yes the gas tank have gas in there .. Quote Link to comment
rad510 Posted June 8, 2012 Author Report Share Posted June 8, 2012 i think is my be a bad ground or a bad fuel pump... cuz the car been sit for 4 years now and just just dump out the old gas out and put new gas in there Quote Link to comment
dennis Posted June 8, 2012 Report Share Posted June 8, 2012 change out the pump Quote Link to comment
rad510 Posted June 8, 2012 Author Report Share Posted June 8, 2012 u know where i could buy one Quote Link to comment
bananahamuck Posted June 8, 2012 Report Share Posted June 8, 2012 What year car are you even talking about .?? Is the engine in a 510 or a 200sx .? Try running a ground and positive straight from battery to pump , ( speaker wire works good ) ,so to go around any relays or bad wiring if it works it could be a fuse, relay or mouse eaten wiring. Try here,, but you will need more info than " it looks like a stock 510 pump " to get any help. http://www.rockauto....ramecatalog.php Quote Link to comment
rad510 Posted June 8, 2012 Author Report Share Posted June 8, 2012 Ok ill try to do that .. My car is a datsun 510 with a z20e napz swap Quote Link to comment
