MariaAZ Posted May 12, 2008 Report Share Posted May 12, 2008 I read Slodat's how to, "Hot Start Relay" about adding a relay between the ignition switch and starter. I'd like to do this to our Datsuns, as well as add a relay to the headlights on our 620. So, I need quite a few relays. Now, for a question with what is probably an obvious answer. All I can find are the five plug relays. Do I just use those and leave the 87a plug open/cut off the wire from the harness? I'm not at all familiar with relays and want to make I've got it right before I buy a quantity of them. Quote Link to comment
banzai510(hainz) Posted May 12, 2008 Report Share Posted May 12, 2008 If you think you have proplems with a hot start use the light relay. Prefer a German made relay this is a 4 blade relay. the 5 balde ai think it has one extra contack just dont use it PS you dont have to cut anything I believe in the stock wireing!!!!!!!! the starter wire should fit on the relay already as for the 620 lights i dont know what you mean Quote Link to comment
MariaAZ Posted May 13, 2008 Author Report Share Posted May 13, 2008 Actually, I was thinking on cutting the spare wire from the relay's harness if I get the 5 blade relays with harnesses. A PO upgraded the headlights on our 620, and now the headlights blow the fuse when they're on for any amount of time. It was suggested that we add a relay between the headlight switch and the headlights. Quote Link to comment
