ratsunissan Posted May 29, 2012 Report Share Posted May 29, 2012 alright so im doing a ka24de swap on my 720 and i want to run a fuel cell because i need to get a bigger gas tank. im hoping one of you can answer my question of what type of fuel cell i need. For example do i need one with a sending unit and a sump or what? the original tank's fuel pump and filter are outside of the tank if that helps Quote Link to comment
metalmonkey47 Posted May 29, 2012 Report Share Posted May 29, 2012 Summit Racing sells a 16 gallon cell with sender unit for about $200. The sending unit is a 0-90ohm. You could set it up in your truck, but you'd need a new gauge to go with it. Quote Link to comment
ratsunissan Posted May 29, 2012 Author Report Share Posted May 29, 2012 damn i dont feel like putting in a new gauge but i guess ill add it to the list of wiring that needs to be done haha. but something like this? http://www.ebay.com/itm/Summit-Racing-Pro-Street-Fuel-Cell-16-Gallon-Plastic-0-90-Fuel-Sender-290108-/370616510277?pt=Motors_Car_Truck_Parts_Accessories&hash=item564a772745&vxp=mtr#ht_1623wt_804 Quote Link to comment
metalmonkey47 Posted May 30, 2012 Report Share Posted May 30, 2012 Yup! That's it exactly Quote Link to comment
ratsunissan Posted May 31, 2012 Author Report Share Posted May 31, 2012 dope thanks man. so what i just need to rewire my gauge or need a whole new gas gauge? Quote Link to comment
datzenmike Posted May 31, 2012 Report Share Posted May 31, 2012 The sender in the Nissan trucks is 10 to 80 ohms so that fuel cell should work just fine. Full is 10 ohm Zero will give a full reading as well. Empty is 80 ohms so when it reads 80 ohms it only means that it will read empty just a little sooner than when it's really empty. Think of it as a reserve. 2wd short wheelbase are 13.2 gal 4wd short wheelbase are 15.8 gal 2wd long wheelbase are 16.8 gal 4wd long wheelbase are 19.8 gal Maybe all you need is a 4wd tank? Quote Link to comment
ratsunissan Posted May 31, 2012 Author Report Share Posted May 31, 2012 alright thanks alot. i kinda wanna use a fuel cell cause itd be different you know, but would it be possible to put the sending unit from the stock tank in a fuel cell like this http://www.summitracing.com/parts/SUM-290104/?rtype=10 or do you think id be better of just buying the other one Quote Link to comment
ratsunissan Posted October 21, 2012 Author Report Share Posted October 21, 2012 ok so i got the fuel cell and my buddy gave me a walbro 255 but im not to sure if that fuel pump would work with the cell or how to hook it up. any help? Quote Link to comment
