79 210 Wagon. Suspension Help
I have a 1979 210 wagon that supposed on custom honda coilover and its bouncy as f*&k but I do not know because I havent got the car running yet but any suggestion for any full suspension set. I was the car pretty low but the ride has to be right. Any websites or compadiable set>?
  • Replies 2
Bouncy means the shocks are bad or not the right units. It's not the springs.
Push down on a corner of the car and let go. It should bounce 1.5 times if the shocks are good. If it bounce 2 or more times, the shocks aren't right.
The right way to lower a 210 rear is to use stock springs, and cut 1/2 coil from each, But don't use a cutting torch (that's the wrong way), use a hacksaw.
